acesneights1
- 22
- 20
- CT
I was towing an M103a3 back from New Hampshire and was stuck in traffic on I495. Was crawing along for about 20 mins when all of a sudden, the truck died.
I was lucky it was downhill and I was able to coast to the shoulder. After cranking it for a bit, it started and idled but stalled again as soon as I tried to give it throttle. This happened about 4 more times until I was finally able to give it a little throttle so I started limping along the shoulder hoping/praying it would make it to an exit.After a minute or so full power returned and I drove it the rest of the way home without issue. A good 70+ miles including climbing hills. Almost felt like it lost the prime ??
I am going to change the fuel filter tomorrow. Other issues I found:
There is fuel leaking out between the engine shutoff solenoid and the PT pump where it mounts. I'm told this is an o ring and simple to change.
Also the primer plunger is stuck out and is wet around the shaft. It was that way since I bought the truck and I have put a good 1000 miles on it. The solenoid leak is new though. Could any of this caused my problem ??
Am I missing something else ? I'm grateful the truck cleared up and drove home fine but now I have a lingering fear of why since I can't really trouble shoot a running truck. I waited till the next day to see if it lost prime over night. It fired right up like normal....Ughhh.
