- 10,859
- 745
- 113
- Front Royal, VA
Anyone have any pics of the 5-ton M923 or M925 on 16.00x20 HEMTT tires?
Nice looking truck!!!!these are mounted on hemmit wheels so the front track is a little wider and the rear track is a little narrower
I concur with Bolkbich. I have 1600s with HEMTT rims. The offset for the front is a little weird, the tires stick out about 3" past the fenders, but it drives just fine.So, are you saying if you mount them on HEMTT rims the front axle width would be wider than the rear? How does that work going around corners?
Would it be better to mount them on standard 5-ton rims if it would be closer to original width?
most vehicles are designed that way. A wider front track decreases the turning radiusSo, are you saying if you mount them on HEMTT rims the front axle width would be wider than the rear? How does that work going around corners?
I like big! I could build some supports for the rear that would be contoured out of the way, but the front hitting would be a problem. I guess it all depends on what I can find a deal on!U are right, they will cut down on turning radius and articulation, 1400s are the perfect match, But I was told on this site , tires are like boobys, the bigger the better, Guess I just like those a little smaller too I have to add for my taste the 14s are just right, but thats me,
