buggin
- 0
- 0
- layton/Utah
Hello
I have a M923-A2 that wont start. Its a 2011 rebuild. It would not start on base, so I had it towed home. It will start on ether. I removed the fuel shut off solenoid. Kill switch off on dash and manually checked under hood, its in the correct position to allow fuel to pass. I pressurized the tank with air. There is fuel past the primer pump. Still nothing.
The only thing that I notice it does differently when priming is that on working a2s you can hear it spraying into the injector, on this one I cant get it to that point. What can I do next to try and get it started. Im guessing its a bad injector pump? Unsure. Does anyone have any ideas what it could be? Or what else I can try? Thanks for your time.
