m923 Air leak
glivdub03
New Jersey
I own a m923a1, when I turn the truck off there is a slight air leak coming from behind the front bumper. It is very hard to hear unless you are close to it. Has anyone come across this problem before? Thanks for the help!
1,174
Fan clutch.
juanprado
2,866
Metairie/La (N'awlins)
there is also an air brake valve in that vicinity of the bumber on the inner frame. Don't recall offhand maybe a relay or quick release.
dmetalmiki
2,027
London England
You might check to glad hand one way valves (towing input lines) As they are mounted close to the location you feel is the source.
juanprado
2,866
Bolts and fasteners are fine thread for the most part. Most plumbing (air, oil, water ) is pipe thread. Some of the assembled hoses assemblies are JIC.
The glad hands and valves are pipe thread.
Not sure if I answered your question?
glivdub03
New Jersey
looked at the air brake valve and it is not leaking, the leak is coming from that area just a little bit higher. I will check the fan clutch any other ideas? Thanks!
