romanservices
- 0
- 0
- Annapolis/Maryland
so I've got the cargo cover and a set of 12 corners, the truck had one complete bow on the bed when I got it. I'm thinking about just making a set of bows and uprights. Like I said I have one already so I can duplicate the curve and length. What material would you suggest using?
Here are the options I have come up with.
order a sheet of 1" x 4' x 8' marine grade plywood and just cut strips
- Steam bend
Composite boards -
- heat bend
Pressure treated 2 x 4 cut down to proper thickness and width
- not sure of best way to apply the bend
thoughts and suggestions?
- Steam bend
Composite boards -
- heat bend
