M923 doghouse R/R
simp5782
Feo, Fuerte y Formal
9,368
Mason, TN
Ha, It is a pain. No fun at all. I just cut an access door in mine when I did my dual fuel line kit. Put a piece of painted plywood over it. sprayed sealing foam under it and mounted accessories to it.
Emmett
Tampa FL
I'm trying to get through the insulated cover over the doghouse just to get to the bolts. What is the seceret to that?
rhurey
14
Bothell, WA
Let me know if you find a secret. Just started, but scratching my head at the ones on the top. Haven't opened the hood to see if "Cut the captive bolts off" is a viable approach.
rhurey
14
Bothell, WA
What's slowing me down is that the top bolts are all under a layer of insulation from the firewall. I can't even see a bolt head unless I somehow cut some insulation back. But access...
rhurey
14
Bothell, WA
Well, pictures...
Here's what I'm dealing with so far. Pulled up the floor mat to find that water had puddled and held under it.
So once the doghouse is all out, I'm likely gonna pull the drivers seat and replace a decent chunk of floor plate. Or just weld new on top. We'll see.
