Bumping an old thread in case anybody else is curious like me.
I found the following ratios. I don't know if these are the actual ratios. ( MT654 vs MT654CR?)
http://www.vibratesoftware.com/html_help/2011/Allison/allison_5speed_auto_trans.htm#MT 654CR
1st - 4.17
2nd - 2.21
3rd - 1.66
4th - 1.27
5th - 1.00
Rev - 10.76
Using this link
http://www.apexgarage.com/tech/gear_ratios.shtml and the data plate info on a M923 for top speed in each gear, here's what I've come up with. If outside links are filtered out, just google "speed in gears calculator" and find one that works for you.
I'm making PLENTY of assumptions here.
14x20 = 49" tall
2750 (!!!) RPM redline (took this RPM in the calculator to make the speeds on data plate to match the gear ratios I found. No idea if this is correct)
So plugging in those numbers ^^^ I get:
15 mph - First
28 mph - Second
37 mph - Third
49 mph - Fourth
62 mph - Fifth
6 mph - Reverse
However, these numbers don't match what yall have above at all so I don't know how accurate this is. My numbers are 1 mph slow in all but first gear.
(That granny reverse gear makes an insane crawl ratio in low. 10.76 rev x 2.21 tcase x 6.44 diff = 153:1)
