M923 or m923a1
randygk
Nampa, ID
Howdy,
Since I'm not having luck finding an M813 close, I will go M923. Can't decide between M923 and M923A1, duals or singles. I will be only using truck to play with, a few parades, shows, or local drives. Any input will be appreciated.
Randy
poorman4x4
-1
Lafayette, Louisiana
I've done all the events you just mentioned including Louisiana Mudfest with my super singles, i dont see any reason why duals cant do the same events. I would only think heavy mud would affect the duals.
Breach27
Bentonville AR
I bought mine as 923 and changed it a couple of months later to an A1. I miss how she handles and rides with the duals, but she looks good riding on the singles. Up to you.
Scarecrow1
Florence , S.C.
Like Breach27 said the A1,s look cool and are by far the better tire for mud and sand but, this comes at a cost. The truck tends to float when you get above 40 MPH. To make matters worse the tires are almost impossible to balance. I also don't care for the fact that regardless of which tire if you have a flat your not going anywhere until you fix it. If I had my choice of trucks just to what you said I would just go with the 923 not the A1.
randygk
Nampa, ID
Well thanks for the input, went to an auction looking at an M925, then I saw the A1, I saw the singles and that was it. Yes at 55mph on certain roads it does seem like a ride at Disneyland, but I'm happy with it. I have another post about lucking out with this truck at GL.
