M923 radiator is leaking
MarcM35A2
Wiehl/ Germany
Hey guys, my radiator gasket on my M923A2 is done. And now the radiator is leaking a lot. already tried to get a new gasket (NSN 5330-01-232-1487) But didn´t find one. Have you an idea how to fix it??? Maybe you have had the same problem and solved it without the original gasket.
Thanks!
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
I know some of the 5ton rads have the top and bottom tank bolted on. I would take it to an industrial radiator shop. I bet they should have the right material for a gasket, if it isn't THE right part number.
