M923 Water Pump Gasket, Can't Find
bsteinborn
Keller, TX
I am replacing the water pump on the M923. I have the water pump and the o-ring but I can't find the gasket labeled number 13 in the Figure below (TM9-2320-272-24-4, chapter 3-6). I have searched for the PN 130226 and NSN 5330-00-106-6370 with no luck. I could always use the old gasket but I'd sure like to replace it, anyone have any ideas? Thanks.
1,174
A google search for "130226 cummins", finds many options.
bsteinborn
Keller, TX
Thanks! My usual search options include "nhc-250" or "M939". Guess I'll start including "cummins" in my google searches. Thanks again, I found the gaskets.
jonesal
Mission Specialist
69
Brookings, SD
Is that the gasket that is supposed to be "leaded" to promote sealing or am I thinking of something else? I guess the question should be: is there anything special about that gasket? I need to change my belt and have read in other posts that its a good idea to replace the gasket with that job.
Thank you,
Al Jones
'84 M923
