gem1410
- 43
- 28
- TOMS RIVER NJ 08527
My trans oil level is at the bottom of the stick at idle --i can not find 10 weight oil----can i use 10-30 to top it off or what do you suggest--thanks
Did you get my reply?Carlo====how long did it take you to set up the shift points on the a2-----is the Allison manual easy to follow --I also have an M923a2 and it shifts at very high rpm--------thanks alot
By the injection pump where the gas cable hooks up to a type of cam you will see a cable befind this going down to the trans. Remove this and screw it out so there is more play. Start a few turns at a time. Try it to see if you need more. This will remove some pressure and allow smother shifts up and down but change the oil to dex 3 too. Please let me know who it goes.Carlo---I did not get your reply about setting the shift points and down shift adjustment------where did you send it--thanks
