IDK about this statement, GM made 1/2 ton pick ups that had rear steering and they were not locked out, it worked both at low and highway speeds,I think there needs to be a position lock in place for the rear steering if it's hydraulic in order for it to be street legal. Might want to look into that before you buy.
Deuce or 105 springs on a 5ton?One can use either the front springs from a deuce that set under the frame or the springs from an M105 that set outside of the frame and have a little more width stability, both seem acceptable. If it's using larger tires, check to see if the front caster has been changed (many threads on the subject here). Without the (front) change, the radials tend to wander going down the road.
That is a common way to bob a 5 ton.5 ton front springs over a 5 ton rear axle
That system utilized an electric motor actuated rack and pinion system... not hydraulic. It used a computer to designate the position of the rear tires in relation to the speed of the vehicle.IDK about this statement, GM made 1/2 ton pick ups that had rear steering and they were not locked out, it worked both at low and highway speeds,
https://en.wikipedia.org/wiki/Quadrasteer
Oops, wrong, had deuce on my mind.Deuce or 105 springs on a 5ton?
This was a very costly mistake for General Motors. For a designated "off-road" vehicle I might consider rear wheel steer, but for any vehicle going freeway speeds NO Way ! I know for a fact that the electrical components would become corroded, then it would malfunction. Now if it was properly maintained they where fine, but that is just something else that must be maintained on a regular basis. Also they were not as strong as a straight axle. It took ten years to develop this unit. A lot of wasted resources for GM.That system utilized an electric motor actuated rack and pinion system... not hydraulic. It used a computer to designate the position of the rear tires in relation to the speed of the vehicle.
