mmerz
- 0
- 1
- United States
This is my first post and would like to say thank you for all the valuable information on this forum. Here is my issue. I've had the truck since March 2015. M923A1 with Cummins NHC250. Truck was running good and then I changed the fuel filter as regular maintenance. I searched and read all the posts on filter change and getting IP prime back. The hand pump won't work so I back filled the fuel line from IP to canister until I got fuel to come out value. The truck started ran for 20-30 seconds then stopped. I changed the primer hand pump and pumped a gallon of fuel through the system. Truck won't start. Added pressure to fuel tank and this forced fuel through system and out an open primer pump. There was no leaks in the fuel line with closed pressurized system and fuel came out the value on canister when depressed. I pumped another gallon of diesel through system and out primer pump to make sure no air was in the system. I opened the IP small screen filter cap (cleaned) and there is fuel in the IP. Primer pumped the system again. There is fuel at the IP but still won't start. Truck will start for a couple seconds with starter fluid but IP is not moving fuel. My guess is the IP is air locked somehow. Attached is a photo of the IP. Is there an air bleed on the IP? or how do I get fuel in the IP to force any air out. I read a post on the 8.3 that showed a bleed screw on the IP pump itself. I figured the prime pump should remove all the air so now I'm stumped. Thank you in advance, Matthew
