- 3
- 1
- 3
- Noblesville, IN
18,885 Miles , last update mods in 2003. Two 6 Month old AGM batteries 4yr warrenty with recipt, Key Ignition & door locks, Locking fuel Cap, keyed ground cutoff switch, GM Style Alternator, Dual fuel filter Kit, Jack, lug wrench, 2 air hoses, Military first aid kit, spare tire chain hoist, new light switch controls, new front air brake lines, CTIS removed axles plugged, 4 year old O-rings in tires with one six months old, 4 year old camo rear cover for bed has been covered with a tarp all the time to protect it, fold down entry ladder on tailgate, troop seats. Cab Floor cleaned primed and bed lined black, new ram air hose to cab from grill, new air dryer installed, full fresh fuel tank with all the additives, fresh oil change, antifreeze. Hard copies of all the T.O.'s in notebook binders, original operators manual.
New Spare parts: 24 volt starter, 2 water pumps, belt idler pully, 2 new air wiper motors, wiper switches, air brake peddle unit, Bendix air valve for brakes that if fails you loose your brakes, turn signal lever, 3 Studderstater valves, Halogen head light replacements, headlight buckets, Cab warning light lenses and o-rings, Military guys Air filter adapter with new filter, spare filters for whole truck, new small cab heater hose, extra shackles, Turbo oil return hose, passenger seat battery box, seat cushions, seat covers, 3 power control boxes , wire and conectors plus much more. radiator hoses. I am doing this from memory and probably forgot many things.
Engine starts quickly and purrs, Transmission shifts well. There is a electrical ground issue that needs to be fixed causing the ignition switch not to activate the starter at times, its not the power control box or the ignition switch, I use a heavy wire to start it at the starter when that happens. Also a few gages are affected as well.
I am being forced to sell the truck to help pay for medical bills for my wife.
$35,000 cash or Cashers check.
Robie Brogan
216 Myers Lake Dr Noblesville IN 46062.
robiebrogan@proton.me
Robie Brogan
