M923A2 disconnect CTIS at the wheels
engele
Nagold / Germany
Hi guys,
after 5 days my rear wheel is out of air. I have a leak and want to check where it is. I want to remove the air line between the axle hub and the rim. Do you have an idea how i can seal the line?
Best regards
Alex
Andyrv6av8r
455
Spartanburg,SC
Start by reading a couple of the previous threads at the bottom of this page. Lots of info in them. Then remove the line at the turret valve and screw in a valve core. Be quick about it since air will rush out of your tire. Re-inflate your tire to the proper psi, wait a few days. If it holds, you have a leak in the CTIS circuit. If it goes down, prepare yourself to replace the wheel O-ring or turret grommet. Have fun....
