allpredatorcalls
- 0
- 6
- St George, Utah
M923A2 Fuel Filters, Draining and Priming.
Okay I dusted out the ole M939 series maintenance manual (TM 9-2320-272-10, Jul 2012 Pub date) to familiarize myself with the fuel system. I decided since I have no idea when the filter bowls had been checked for water and or sediment, I would do that.
The manual is somewhat confusing / poorly written and shows illustrations that are not reflective of the configuration of my M923A2 with a 6CTA 8.3L turbo motor
I have a few questions for you guys with more expirence.
1. I have the driver’s side fuel filter assembly. The maintenance manual WP0119-6 step a and b says it requires daily draining.
Does anyone do this that often? What’s a more realistic schedule?
2. The maintenance manual WP0119-6 step b. says open the inlet drain valve (fig 5 item 1) my filter doesn’t have the valve. I did open the drain valve at the bottom of the filter bowl (fig 5 item 3)and it just sucked air for 4 or 5 seconds, so I turned it closed not wanting to induce a bunch of air into the system, it never drained fuel.
So what is the proper way to drain / check for water in the filter bowl on the wheel well filter? Let it suck air and eventually it will start draining fuel?
3. Regarding the engine mounted fuel/water separator the maintenance manual WP0119-6 step c says open the drain valve, drain into a container, and when done prime the fuel system. WP0119-6 step 2 lists the steps for priming the fuel system. The steps (b and c) refer you to the open air purge valve and a hand primer pup (fig 6 item 2) of which neither are installed on my truck in the position depicted in figure 6…. So what gives? How are you purging the air from the system.
4. I looked further into the maintenance manual TM-9-2320-272-23-2 WP0239-2 (priming fuel) which depicts my fuel transfer pump configuration. Based on the paint on the vent screw, and its location, I would guess it hasn’t been opened / purged since it was painted in overhaul back in 2009…
- So is the fuel/water separator drain another one of those things that is supposed to be done daily that never gets accomplished? Does anyone do this that often? What’s a more realistic schedule?
- What technique / procedure have you that have similarly configured fuel systems been using to purge air after checking for water or replacing fuel filters?
Thanks for your help
