M923A2 motor dead
Grob
Longmont,CO
So my A2 was fired up a few days ago (by my bride), and she chose to ignore the idiot light flashing low air pressure, and put it in gear (before proper air pressure). shortly thereafter the motor died, and now it cranks with not a sputter. I assume it has to do with solenoid on fuel pump, but I can seem to get it to reset? When I reset counter clockwise, it still wont start, and when the ignition is turned off, the solenoid resets the shut off to the clockwise position. Only had the thing a few weeks, and had not spent a lot of time tinkering to know what is what. any ideas would be greatly appreciated, so my darling can stop catching heck from me.:wink:
MtnSnow
14
NSL, UT
If it cranks and while it is cranking you have made sure that the fuel kill lever is in the counter clockwise position, I would say you have lost your fuel prime. Use the manual prime button on the lift pump until you hear the "squish" of fuel being pushed past the fuel return check valve and then try cranking it over again.
1,177
How was it shut off ? If. you didn't turn the switches off in the correct sequence you could've damaged the PCB. manuals are available for these trucks
Gunzy
66
Roy, Utah
OK, I have to ask. Is there plenty of fuel in the tank? Just seeing what may look like a 1/4 tank may not be enough. The fuel is empty when there is 5-6 gals still in the tank.
gottaluvit
Indeed. I had 1/4 tank on one tank and knew darn well I should have switched tanks and drove it home fine. Next time I went to start it, it failed to start. I switched tanks and pumped up the lift pump and it fired right up. I realize you only have one tank, so it's worthy of hauling fuel cans and get it up to half tank to eliminate. Doghead has a good point, but I doubt putting it in gear with the brakes still locked hurt anything.
Aruba1
BHM
Once the air builds to an acceptable level (60 psi???) then the brakes will release so the truck can move but the low air pressure has nothing to do with killing the engine if it's put in gear.
Grob
Longmont,CO
So it was the loss of prime. pumped the primer bulb several times and it sputtered and started. Aruba1 suggests there is not kill feature to throw the shut off solenoid if dropped into gear while low air buzzer is going off? It is right around 1/4 tank on gauge, but as I said it fired fine, my wife neglected to wait till low air buzzer went off, and engaged in reverse. Within a few seconds it sputtered and died. The missing piece I did not realize, was she and my son cranked on the motor thereafter and thus introduced the air (or more air) in fuel system?
Either way I will top off the tank, and tell the bride hands off :)
thanks all.
74M35A2
330
Livonia, MI
Your wife didn't do anything wrong. Way cool she will get in and handle it. An A2 doesn't need the fuel cut reset. The fuel cut solenoid is problematic though on these. It will go to stop mode even after extended cranking as it heats up and battery voltage drops. I say add 10 gallons of fuel, open the purge relief on the injection pump, pump the primer 50 times or until fuel sprays out with each pump, close the relief, charge the batteries, zip tie the fuel cut solenoid into the fully retracted position, spray a whiff of starting fluid into the fresh air inlet screen, make sure the fuel cut cable is fully pushed in, and crank again with pedal half way down. It will probably be fine. You torque converter may be in lock-up, check the chrome button on the end of the transfer case lever and see if it is stuck in.
