M923a2 trans question
mcmullag
13
Colorado Springs, CO region
I gotta get the popcorn out to watch this thread.
It can be 10 weight oil, 15w-40, or some auto trans synthetic stuff.
An active duty wheeled mechanic here at Ft Carson recently advised me they were putting 15w-40 in everything to keep it simple.
The -10 manual will specify different fluids for different ambient temperature ranges (if in Alaska or different if in Hawaii).
Coffey1
493
Gray Court SC
There is no solution to this.
You have just entered the twilight zone.
Trans oil is like women every person has a different opinion on what they like.
I myself just want a smooth well running one that has no issues. If she ain't fussing be happy.
gem1410
42
TOMS RIVER NJ 08527
10-30 diesel motor oil looks good for NJ temps---what is the oil quart amount for the hash lines on the trans stick --that is what I would like to know--did not see that info in the manual--thanks
Coffey1
493
Gray Court SC
Suprman
665
Stratford/Connecticut
Kind of a catch 22 though since you dont want to drive it to warm everything up till you make sure the trans has proper fluid level.
M35A2-AZ
376
Tonopah, AZ
That is ture, On a new truck I check it cold then drive it a little and check it again.
plode
South Jersey
My truck took 5 gallons, but I also had the pan off and changed the filters.
