jetjockB747
- 3
- 18
- Palmetto Bay/ Fl
Need help sorting an issue with the instrument cluster voltmeter. Old meter was tested and failed continuity test. Installed new unit, but no dice. Meter still dead. I understand there is a 5 amp fuse on the feeder line from alternator leading to voltmeter. I suspect a blown fuse might be the cause. Any insight into were this fuse is located? Also any troubleshooting tips would be appreciated. Im down to this last item on the gig list but can't seem to solve. Thanks.
