M923A2 Wiper Motor
dawico
Lampasas,TX
When does it leak? All the time or just when you use it?
I assume it isn't just the air exhaust when in use, correct?
I haven't had any issues with mine (yet) so I am not familiar with the symptoms.
jcollings
389
Jupiter/FL
-m923a2 has a passenger side wiper that after losing air pressure it drops down anyone ever heard of this or possible cause
74M35A2
330
Livonia, MI
A small engine fuel filter or sintered air muffler/filter on a short hose on the air wiper exhaust can silence them by 90% with no loss of performance.
Pull your wiper motor motor hoses off and squirt some air tool oil in there and then run them. It may be all they need. Valve may be suspect also.
Csm Davis
393
Hattiesburg, Mississippi
Oil them as said above and try pushing in the button, if it is stuck in try pulling it out. I like converting to electric system off M35A3.
Sent from my SM-G900V using Tapatalk
