M923A2Parking Brake
Navo
Chesapeake, VA
So I've noticed recently that when the parking brake is released (the handle all the way down). I can still hear the high pitched tone of low air buzzer/parking brake is still on. The light on the dash is not flashing or steady on and the brake is off.
I have traced the wires and I don't see anything broken. Any suggestions as to what's causing this?
juanprado
2,866
Metairie/La (N'awlins)
many threads on this.
Search failsafe warning control module.
It uses the air pressure switches on each tank and the parking brake. Problem can be anywhere. The newer tm 23 series released Sept 12 has great trouble shooting flow charts (work packages) and on the 5 ton forum sticky is the p2p software with excellent wiring and air line schematics.
http://www.jatonkam35s.com/jatonkaM939seriesTMdownloadpage.htm
1,174
Are you saying we don't have those TMs on SS?
1,174
http://www.steelsoldiers.com/showthread.php?79228-TM-s-for-the-939-series-trucks Look at the last link listed at the bottom.
here's the actual link we list. M939_P2P.zip
M939 Series Interactive Systems Guide - Download .zip file, right-click the .zip file and select unzip contents, put the M939 P2P file in your Program Files directory, open the M939 P2P folder, right-click on the runa6w32.exe file, select Send To, select Desktop (create shortcut), go to desktop, right-click on the new shortcut, select properties, select the shortcut tab, make sure the target box shows "C:\Program Files\M939 P2P\runa6w32.exe" c:\Program Files\M939 P2P\nav.a6r, make sure the start in box is empty. This should allow you to double-click the shortcut on your desktop and start the P2P program.
Is this what your refering to?
1,174
So, we are missing some? Could you please help me improve our site and provide me with a list of the actual TM numbers your refering to?
Here's a picture of the link to the 2012 TMs for M939 trucks that is available on SS.
juanprado
2,866
The newest ones released or updated in Sept 2012
Tm 9-2320-272-10 (updated)
Tm 9-2320-272-23-1 (new Series with abs)
Tm 9-2320-272-23-2
Tm 9-2320-272-23-3
Tm 9-2320-272-23-4
Tm 9-2320-272-23-5
Tm 9-2320-272-24P-1 (updated and expanded also with abs)
Tm 9-2320-272-24P-2
Tm 9-2320-272-24P-3
Jatonka and Ichdov have them on their websites if you want to grab them and put on ss :)
4,729
Tm 9-2320-272-23-2
Tm 9-2320-272-23-3
Tm 9-2320-272-23-4
Tm 9-2320-272-23-5
Tm 9-2320-272-24P-2
Tm 9-2320-272-24P-3
That's the reason I made the TM upload section, when people find newer ones they can upload them here:
http://www.steelsoldiers.com/forumdisplay.php?154-TM-Upload-section
gringeltaube
Staff Member
2,465
Montevideo/Uruguay
Very good! Let's start uploading then...!
So there is a -10 from JUL2012, and then an updated version of the same, from SEP2012 ???
G.
juanprado
2,866
Yes the -10 is July not Sept.
I can not upload as it errors out. Tried 3 different times with 3 different manuals. I think it chocking on the 50 mb uploads.
Patracy,
Please download from jatonka and upload as I keep getting errors.
4,729
Unfortunately it's a fine line of upload speed of a user and the timeout max setting for the server. (If I open it up, any time someone tries to upload an image/file/pdf, it can suck up too much bandwith)
I'm in the midst of the server migration. So I will not be uploading anything presently. (It's just more to have to migrate over twice)
Once we're on the new server, I will investigate upping the timeout for uploads.
