M925a1 Rockwell axle I.D. and locker info Please!
Purplerambler69
Thayerton, Pa.
Can someone help me out please? Im trying to find a locking differential for my M925a1. No luck with Memphis Equipment or TNJ Murray. I called direct to Eaton and they said I needed to positively ID the axle housing. I gave them my model# which is M (I believe, hard to read) 1240rdax 2a. I also have the serial # from the axle tag: M (again I think) k85030037. I spoke to a person at Meritor and they said those axles were discontinued. The M925a1's aren't THAT old are they? My trucks serial # is C52502557. Surely somewhere in the world someone still produces parts for these axle. Any and all help is appreciated! Thanks!
4,739
I actually just received my locked 939 series axle this AM. I can try to check on the tag number and compare it to a non locked tag. If you're thinking of buying one new, be warned, you're in for sticker shock.
The 5 ton rockwell axle is a very old axle. The 939 series used the same axle (just with brake upgrades). The M39 series trucks were first started back in 1951.
On a side note, my axle came from PA!
4,739
Ok, just went and pulled the numbers.
My normal non-locked rear axle on my 931 chassis is:
M (looks like it I think) 1240RDAX 2A
The locked rear axle I just got has:
M (looks like it I think) 1240RDAX 3
Purplerambler69
Thayerton, Pa.
Thank for the info Patracy! After about 9 different phone calls I finally found a pair of new Detroit Locker units. Mark at Boyce Equipment told me he thought they had 4 of them left, after the 2 I ordered. A couple guys told me that they were going to try to get Eaton to start making units again, but its definitely not for sure that they will.
