M925A2 ABS relay valve leak
146APF
LHC/AZ
Right side rear ABS relay valve leaks from exhaust port when service brakes are applied.Removed valve-rebuilt/cleaned reinstalled still leaks.Could not find any info in TM's .Any ideas? Thanks
hklvette
Christiansburg, VA
Mine leaks as well, but all the time. I'm going to get one from a vendor here and take my leaking one out to see if I can get a COTS rebuild kit for it.
Floridianson
2,487
Interlachen Fl.
Any luck on the rebuild kit for the modulator valve. Mine has a very small leak out the exhaust when I shut down and set the brakes.
