M925A2 air seat installation?
slayden1
Chattanooga tn
I just purchased a air ride osh kosh seat. I am trying to figure out the best place to bring the air from? I have seen a air accessorie block in some TM but do not know where it's located.
Floridianson
2,485
Interlachen Fl.
There air three air lines buy the hand brake. You can tap into the one closest to the rear of the cab with a T. That line comes from a tank supply. It's where I did mine anyway.
Suprman
665
Stratford/Connecticut
If you want to do it from in the cab and run it under and around you can tap into the ctis air feed line. If you are in the engine compartment looking at the firewall by the governor its the copper line that is looped. After it comes in thru the firewall it is adapted to a plastic line.
Daytodog
Harrisonburg, Va
I also did the same thing as Floridianson. I picked up the Tee at a local truck center connected it to the rear air line also like in his picture and have had no problems either.
Jayco36REQS
Orlando/FL
Ditto for the way I did it with my air-seat back in Sept... Super easy install and works like a champ!! :beer:
slayden1
Chattanooga tn
Thanks so much for all the great help guys. It's awesome to be able to ask how others did something without all the crap answers you get at the OTR parts stores. Real world experience is priceless.
