74M35A2
- 329
- 83
- Livonia, MI
Took advantage of our cold spell this evening to check cold start-ability of my newly acquired 1991 M925A2. Installed new $48 NAPA (Katz) ether cylinder 2 days ago into factory injector system. Outdoor temp not including wind-chill was -11F at time of test, truck was located outdoors and slightly snow covered. Fuel is about 1 month old, and has Power Service brand anti-gel added (white bottle, not the "911" red bottle). Batteries are 4 military type, under pass seat, and dated 2009, believed to be fully charged from idling 2 hours 2 nights prior.
Using the ether-assist during cranking, the Cummins 8.3L came to life in about 2 full seconds of cranking, ran smooth, then fell on its face as the ether burned off. A single repeat of this cranking with ether again, and the truck stayed running on diesel with the accelerator depressed past idle position (which was also partially depressed during the first crank/run attempt). Took several seconds of running like this before all cylinders were firing and idle was stable, but overall, I was very impressed for an engine without any type of heat assist. Oil pressure came up quickly. Engine started so quickly at this frigid temp, I am not sure I see the advantages of a block heater unless it is an attempt to get the dismal cabin heater to blow warm air more quickly.
Wanted to post the results for reference if anybody finds it advantageous.
