74M35A2
- 342
- 83
- Livonia, MI
Seeking similar cases of front driveline vibration at higher speeds (>40mph), which disappears if the front drive is switched on, and what your resolution was.
I'm so far guessing a U-joint or knuckle joint in one the front axle shafts, but also wondering if back-dating the front driveshaft to the previous generation front driveshaft with a carrier bearing would help resolve. The truck did not have this issue until recently. May just be time to pull the front hubs down to the bearings and see what we have.
Thanks in advance.
Thanks in advance.
