M925A2 Washer Bottle Threaded Hold Down Ring, Pops Off
74M35A2
313
Livonia, MI
So, when I use the washers, the bottle pressurization pops the metal ring up and off the bottle. Vent in the top plate is clear and working.
Anybody resolve this fairly easily without switching to electric?
Thanks.
tmaxxgod4
anaheim ca
mine was NOT electric mine is AIR.
it exploded when I push the button. what I did was check it out and under the white cap and the 2 smaller hoses (one is air one is water) were broken off so I got a new cap with all hoses attached, it fixed my problem.
ALSO if there NOT broken off then take the 2 hoses on top off and have a buddy hold both hoses and see what hose shoots air out when you hit the button that hose is the AIR hose the other is WATER plug the AIR house into the A part and the water hose into the W part. then zip tie the air house onto bottle.
if this is not help post pic of your washer top and bottom and I will highlight what I said in pics.
If no one has pics of there's up by tomorrow late noon I will post pics of mine.
70deuce
115
Franktown, CO
My top would not tighten up at all and just sat there loosely attached. Leaked all over the place when it was more than half full. I wrapped a 1 inch wide piece of tire tube around the threads at the top of the bottle and that tightened everything up nicely. The top stays on and seals fine. I also will post some pictures after light tomorrow.
capnkirk
Miami, OK
My wiper fluid comes out like a morning piss. Some of it washes the top of the cab, fenders, mirrors, hood, and road. Does NAPA or anyone have replacement nozzles and rubber bushings to mount them?
Swamp Donkey
The Engineer
119
Gray, GA
Instead of starting a new thread I'll use this one...because I did a search and this is my proof.
What is missing from the lid in the center? In a picture above it appears to be a little cap. Is it a vent, or what does it do? Can it be replaced with something common?
Andyrv6av8r
454
Spartanburg,SC
It is the vent for the bottle. It's a very fine mesh that can get very brittle with age and disintegrate. Just find something that breathes and keeps the dirt and critters out.
