M927A2 / M939- Strictly reliability upgrades and modifications.
rbr0203
-1
Kenosha WI
I've been searching this site for good modifications. I have found plenty of mods that i will try when i have the money and the time. My question is if you were to try to make your 5 ton more reliable, more bullet proof, what would you do? I assume we would all try to change all the fluids, possible battery change, and inspect wires for shorts and such. However, i know most of the gentlemen here have lots more experience and screw ups over the years to provide much needed wisdom. Thanks in advance.
:grd:
NDT
7,530
Camp Wood/LC, TX
Replace the humpty dumpty transfer case with something less of a ticking time bomb.
simp5782
Feo, Fuerte y Formal
9,512
Mason, TN
More power = more stress of weak components. As NDT said, the transfer case is the weak link. Any engine upgrades will take that power right out on that. Heat is the killer for the transmission. Bypass the heat exchanger and run a total air to air system for summer or towing but keep the heat exchanger for winter time in your neck of the woods for faster warm up times for driving.
Oil Filter bypass systems are very helpful with keeping contaminants like water and fuel out of the engine. They have a built in heater. You will find little quirks and what not to improve your truck to your liking. I can get in the drivers seat of mine and do 14 hrs straight and never get out of it, but i get in one of my other ones and im irritated with it in 5 mins. My 923 is highly modified. It is suited for what i want and what it needs to handle. I have upgraded the transmission, transfer case and drivelines before i am doing the motor swap so I didn't put too much power under the hood just to spend time blowing everything else apart when they are still good useful parts.
Someone suggested me leaving my 939 transfer case in until after the big cam swap and if it blows it blows. Why would i blow a $1200 transfer case when the replacement costed me $100 and i could sell a known good one.
rbr0203
-1
Kenosha WI
Yeah so i kinda figured that out when i was moving it to a better storage location the other day. Ive driven these a couple of times when i was deployed but never as the primary driver. Little did i know that the transfer was already in low (did a small three part turn with it too, i know, know never go in reverse in low but i didnt know it was in low). I start going down the road and i couldnt get it above 30 mph. So i pulled over into a grocery store parking lot to figure out what was the matter. Ive never done anything with switching from high to low and visa versa. It didnt engage for the life of me and took several tries. finally got into high and low and behold i could get to 50. what a pain.
rbr0203
-1
Kenosha WI
What would you say is an acceptable level of horsepower without issue? id eventually like to add more for towing a trailer and truck. I havent looked into the trans oil bypass yet so ill have to look into it. i also didnt know that the oil filter bypass had a built in heater, any suggestion on where to look for that? I plan on trading out the seats with leather aftermarket ones. I was looking at the gauges and lights, why would anyone paint over the indicator lights near the gauges? I took them off and all of them were originally clear. How did you upgrade the transmission, transfer case, and driveline if you dont mind telling me?
simp5782
9,512
Mason, TN
My drive lines are 4in diameter shafts. Much bigger than 5 ton shafts.
I have some threads on the cat 7155 swap and the oshkosh transfer case swap. The cat will not mate to an 8.3l truck though
You can get on up around 330hp and you will be fine. Add a bigger transmission cooler and maybe a transfer case cooler.
The oil filter bypasses are from puradyn and on Ebay for cheap.
Sent from my SM-G965U using Tapatalk
rbr0203
-1
Kenosha WI
are the drive lines / shafts hollow or solid, if hollow what thickness are the tubes walls? what would you suggest i and others look into for a trans and transfer case with you experience? thanks for the heads up on puradyn.
rhurey
15
Bothell, WA
beyond "change all fluids"
Thinking of all I have done...
Coolant filter
Block heater
Service air drier'
Multi-bank battery charger
Adjust transmission modulator
Check axle vents
rbr0203
-1
Kenosha WI
Coolant filter
Block heater
Service air drier'
Check axle vents
[/FONT][/COLOR][/LEFT]
axle vents makes sense and i didnt think of them. come to think of it is there parts on the vents for the fording package?
dont even know where to look for the air drier yet lol
this was attached to the green line in the cab, looks like a mini air/water separator. However, its leaking air like a sieve.
simp5782
9,512
Mason, TN
That is For the ctis as a water catcher.
Air dryer is back on the frame.
Most of the axles just have check valve vents. We normally put hose barbs in em and run a hose up to clear any terrain
Driveshafts are hollow. They are heavy enough as they are. You couldn't lift a solid driveline on a 927. Especially the front driveline
simp5782
9,512
Mason, TN
Is it supposed to have air leaking out the base? I feel like it shouldn't
Sent from my SAMSUNG-SM-G900A using Tapatalk
No. Pull it and clean the bottom of it out and make sure it isnt cracked or stuck open. or disable your ctis
silverstate55
Unemployable
1,095
UT
As Simp5782 said, take it apart & either clean or replace the little O-ring at goes on the base (drain petcock). The O-ring is either dried/cracked or in need of some rejuvenation with some silicone grease.
rbr0203
-1
Kenosha WI
Unfortunately it's leaking out the bottom piece. Looks like it was broken off or the release was gone. i purchased a small aluminum water separator from a bagger website. Ill install it and see how it works.
