M929 transmission hi/ low problems
tomtwigg
Ridgeland SC
Hi
I have a problem with my transmission low range. I can only put it in low range when the engine is off. Then when I start it I put the transmission in 1st drive the vehicle lunges and will not stop.
ericp351
106
erie Pa
2 thoughts. Trans converter is stuck Locked, as it should be on top gears ONLY. Try in "1-5" setting or high range as the trans doesn't know what your trans case is doing. Basic- check out and adjust your linkages if binding. Good Luck.
