- 26
- 31
- 13
- Guilford, Vt.
In another thread I talked about my wheel stud issue. At the time of the incident, I got the wheel off and the Brake Drum came off in my hands easy. Got New Studs and Wheels Seals as I thought about replacing the Brake Shoes if nessecery. I'd had a leaking wheel seal and figured they were soaked in gear oil. I had to Beat the Hub off with a Big Hammer, but the Axle Stub is clean with no burrs, bad spots, or decolorization, and the Bearings are fine. I don't get why it came apart so hard. I've done numerous brakes and wheel bearings on civilian trucks and trailers and never seen this kind of arrangement. Two Inner Wheel Seals, A Fill Plug at the Outboard End of the Axle, nor this Plastic Gizmo inside the Hub. How does all this work? According to the TM I saw it reads to inspect, clean, and Repack these wheel bearings once a year with GAA. Don't they run in GO? Maybe I was reading the Wrong TM, IDK. What's the point of Two Inner Wheel Seals, a Hole in the Axle, these Different Ports below the Bearings, and an Outter Fill Plug? Aren't the Bearings all lubricated from the Differential? I'll be the first to admit I know very little about these trucks, and just want to know how things are supposed to work to prevent further breakdowns.
Upon inspection, there is plenty of life left in the shoes. I degreased them, and pressure washed the whole unit. Reinstalled all the Wheel Studs. I think.... One of The Outter Wheel Seals was installed incorrectly as the were Both pointing in the same direction with the flat solid side down. The Inner Wheel Seal is a no brainer. I reinstalled the bearings "Dry" with just a light coating of Lucus Oil Stabilizer. The Hub went on easily only to a point, where there wasn't enough room on the Axle Treads to get the Lock Nut On and I had to Beat The Hub on with a hammer to gain threads for the lock nut. The TM calls for approx 50' lbs torque for the Axle Nut while spinning. I did all that and the Hub turns freely even after beating it in place. I don't understand all that either. I never had to beat a Hub off, or back On an Axle.
Now the Brake Drum won't go back on. I didn't change any adjustments on the Shoes. Of course the Adjusters are semi froze up, (Gonna try and find New Ones), and mess with it some more today. Only thing I can think of is soaking the shoes with Degreaser and then Blasting with my Pressure Washer made the Linings "Swell" some, and even that doesn't completely make sense either.
I think this whole set up is kinda stupid, but there must have been a reason for it. Any insight to my dilemma will be greatly appreciated. I want to learn and do this thing up right. Thanks.
