In addition to the air brake problem I posted earlier, I have a problem with the fuel system not holding prime.
Before starting the truck I have to bleed the air out of the fuel lines with the hand priming pump. Once I do that it will start right up and run fine.
If I shut it off for 10 minutes I have to bleed it all over again.
When I first got the truck someone had turned in the screw on the solenoid fuel shut-off so you couldn't shut the engine off without pulling the emergency fuel shut-off. I backed off the screw on the solenoid valve and now it works like it should.
I've heard the tank selector valve on the floor by the door can cause fuel priming problems, but this must be a pretty good leak to lose prime in just a few minutes.
Any idea what the problem is?
