m931a2 5 inch turbo back exhaust
mreuss222
sandgate vt
has anyone found a down pipe from the turbo that would fit?
looking to do 5 inch exhaust from turbo back. not just cut under the cab and hook up the 5 inch.
thanks
simp5782
Feo, Fuerte y Formal
9,338
Mason, TN
thanks
No need to make multiple threads. The exhaust has been done before. Easiest way to do it is a 4in v band flange to a 5in adapter then the 5in pipe on a 45 degree. I did it on mine but my exhaust is routed totally different. Mine is on a non turbo truck but the same principle
Sent from my SM-G935P using Tapatalk
mreuss222
sandgate vt
I did a search on down pipes didnt find anything.
I appreciate the info and photo
thanks
Jbulach
2,141
Sunman Indiana
Thats still only 4” and it would need major modification. Like simp said, adapt the turbo up to 5”, then two $30-40, 45 degree elbows will match the factory pipe perfectly. A piece of flex, a 90 and stack and you’ll have the rest. The 8.3 are supposed to be tolerable without a muffler...
