M932A2 injection pump problem
anymech
westfield, IN
I own a M932A2 Cargo Truck (manufacture date 06-90) with a 8.3 liter cummins with Bosch injection pump. i have good fuel pressure and flow to injection pump. no fuel to injectors when cranking, i cracked open all six lines at IP going to the injectors. engine will fire and run briefly, when i spray starting fluid into air filter housing (housing open, air filter removed). what i believe to be the IP selenoid is working, it does get hot after cranking for a while. i am afraid the IP is bad internally. i did open the front engine cover to make sure the IP gear is moving and it is. How can i test this further?
M35A2-AZ
392
Tonopah, AZ
Did you open the bleed screw on the back of the pump and pump on the primer pump till fuel came out?
MtnSnow
14
NSL, UT
Along with what M35A2-AZ said I would for testing purposes REMOVE the shutdown fuel solenoid and physically make sure the fuel shutoff is completely rotated into the "run" position.
