M934 Expansible Tire Pressures
captcarc
Canton/TX
Hello. I have an M934 Expansible with ABS but without super singles or CTIS. So there are 10 tires on the rig. What air pressure should I run in the tires, especially the fronts? Thank you very much!
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
on G177s run around 65 to 80 in the front. 40 to 45 in the rear. You should play with the pressures anyways to get the best ride quality. Not everyone is the same. the pressures may not work well for a loaded truck vs an unloaded one.
Trailboss
137
Norwood LA
Refering to the TM 9-2320-272-10 for M934s, Table 1-10 gives front 90psi / rear 70psi for highways, and front 60psi /rear 30psi for cross country with 11x20 tires. Those pressures are assuming a full load, so you could probably reduce them for a smoother ride empty. I've seen a full range of pressures painted on the wheel wells, so I guess it was up to the unit to set tire pressures.
