Csm Davis
- 382
- 83
- Hattiesburg, Mississippi
Last couple of days we have been busy fixing a badly damaged M934A2 and adding a M927A2 bed to it. It had bad fork lift damage to the hanger bearing, fuel tank mounts, and air lines. The rear emergency gladhand was ripped loose and air line cut, the air line to the intermediate axle abs was ripped and plugged, and the main air lines to and from the air drier were crushed. 30 foot of new lines and ferrules and inserts got the air fixed up with a repaired gladhand and air system. Then a quick run to Wansley Machine and Driveline got the hanger bearing and two new u-joints replaced so then we could drop on the bed.
Sent from my SM-G930V using Tapatalk
