My M936 (FLUFFY) is almost ready to run with it's new Big Cam 3 engine upgrade. NTC350. Thank you to everyone who has posted their comments about their engine swaps. They are very helpful. To repeat other comments about what you can expect. I had to do the following.
1. Front engine mount needed some serious fabrication work to get the engine aligned properly. I made a completely new engine and frame mount.
2. Fan clutch mounting hardware needed to be fabricated to get the right position with existing radiator. Spacer needed to be machined for drive accessory fan belt pully alignment with fan clutch
3. Alternator adapter plate was made to align existing 24vdc alternator.
4. Transmitting flex plate housing needed upper left hand bolt hole reamed out to mate up with engine.
5. Be sure to jack up front of cab 4" to get engine out and in. It is a heavy monster, use rated hoist and be safe.
6. VS fuel pump from existing engine needed to be worked up to run the ntc350. I am having this done at a diesel shop. Need the VS pump instead of the PT pump for constant power while running PTO.
7. Turbo intake piping needed some fitting and fabrication. Same with exhaust piping. I added a 5" muffler stack to replace 4".
8. May need to add 1" cab lift to clear back of engine in firewall. I have about 1/2" of clearence.
9. Everything on this truck is heavy and I have lost 20lbs and my muscles are getting toned. Women have noticed and have been seeking me out. Thank God they don't know where the shop is. I wouldn't be able to get any work done because of the line at the door.
10. More modifications are coming, but I need to get this part done first.
Those are just the highlights. This is a serious project and not a weekend swap out. I am on week #5 of nights and weekends and I have about 2 left...
I will upload pictures when I am done. To say that I am excited is an understatement.
