- 7,541
- 19,390
- 113
- Charlotte NC
Hi All, These may be old tired questions but I seemed to come up empty trying to search for answers. The indicator lights in the picture below... I know for certain that the AIR LOW lamp is working. Turn on the truck, that lamp lights, the buzzer turns on and until air pressure builds - it stays that way. My PARK BRAKE lamp does not turn on when I pull up the handle beside the transfer case lever.
Is there a tool to use that engages those two "nubs" on the red indicator lamp covers? To unscrew the red cover and gain access to the bulb? My idea is use the known working bulb to test the non-working socket... I presume that the green lamp cover uses the same bulb as the others? TM seems to indicate that to be so?
![Brake Light AddOnMaybe.jpg Brake Light AddOnMaybe.jpg](https://www.steelsoldiers.com/data/attachments/555/555746-647bbfe41dc652ca938f4fc473a15a0a.jpg)
Another more general question: The BRAKE lamp that appears to have been added later. Is that normal? And more specifically the wiring that is just hanging out in thin air... Is that normal?
Last of all - OPINIONS WELCOME - Should I just replace those bulbs with red LEDs and are they readily available? My truck has no chance of ever being in any sort of contest for being "all original" so that isn't an issue.
![Warning Lights M936.jpg Warning Lights M936.jpg](https://www.steelsoldiers.com/data/attachments/555/555745-d1791e488aff0d3a84dba72bd6800e19.jpg)
