Picked up the M936 today from Hammond to Covington, La. today. Made it home ok but it was a long day, the truck was sitting for 4 years and in a mud hole no less. I brought the M931 I picked up from Shelby 2 weeks ago (Great Truck) to pull it out the mud hole where we could work on it, no dice. One set of rears were locked up
My 2 sons, my brother and Dad were there to assist ( my Dad to give orders) we took the control box off the 931 put it on the 936, added batteries and she fired up fairly quick, we moved her to some concrete where we were able to free the rear brakes that were locked. A broken hose on the power steering cyclinder had to be repaired before we burned the power steering pump up, went to get fittings and fluid repaired the lines, aired up the front tires. We then hooked it up to the 931 with the tow bar, air lines and safety chains. We then checked to insure the brakes worked, all lights worked and we were set to go. We then removed the drive shafts and started the 30 mile trip home. As soon as we pulled in the drive the bottom fell out, the 7 1/2 hour trip worked out well, I only drove 35 MPH on the way home and the 931 was a mule it pulled great!! I did reach 40 a few times but noticed a little sway so I kept the speed down.
Will take some pic tomorrow of both trucks while they are hooked up.![Razz :razz: :razz:](https://www.steelsoldiers.com/images/smilies/icon_razz.gif)
