- 7,408
- 2,501
- 113
- Interlachen Fl.
I have a 1982 M925 with the chamber showen in the pic. I took it compleately apart and here is what I found. The truck parts place had the D12 and D16 diaphrams. The D12 fit the lower marked in black but was thicker at the seal edge. The D16 has a taller hat or depth to it and there is a sealing lip that it must fit into to seat correctely. I watched a vid here on SS from Acme66 and if you watch he had a sealing problem the first time because the diaphragm was not seated into the lip on the lower unit. I will be calling monday to a shop that says they know these chambers. I have a feeling these units with the tabs that require the parking brake spring cap to be taken off sideways ( pic marked in red) are nonrebuildable uppers. I did get mine rebuilt useing the D16 but had to flip the diaphragm the outher way to get it installed.It's working and holding air but I just think it's not right) I have done outher chambers before where you remove the band clamp and the top cap comes stright off but never seen this type. I had to remove both upper and lower chambers from the truck to work on this unit in the shop and get the D16 to seal right in the lip. I will post some pis later and report back with what the axle shop says.
