M939 fuel tank dimension question
montaillou
828
W.WA
I'm thinking of mounting a 81 gal fuel tank from a M939 on my deuce.
I'm trying to figure out the total space and I think mine might be tight.
I wonder if anyone's that got one mounted could tell me the width - from the frame to the outside of the tank (that is, the tank with the brackets)?
Thank you for any assistance.
74M35A2
318
Livonia, MI
I'll measure and post this for you late tonight. My truck is an A2, so it has the angle filler neck. Core tank dimensions may be same as A1 and first gen, not sure, but assuming to be so.
Anvilface
Wilmington Nc
I just measured ours. On a 923a1...fuel tank size from outside to frame rail about 24 inches. Add about 2-3 inches for the bracket at the frame rail. The height of the tank is about 17 inches, and the length (bow to stern) is about 43 inches. Hope that helps
