M939 series power steering box leak
gottaluvit
I was lubing my truck to day and noticed a grease fitting on the bottom of the steering box by it's input shaft. The only leak this truck has is that seal where the steering shaft goes in the box. Figured maybe some lucas power steering sealant/revitalizer would go in when it needs added to. So I shot some grease in that fitting and it came out of the box where the shaft goes in.
Does grease being pumped into this fitting stop any leaks or is it a real bad sign I will have to rebuild the box since the grease came out? Is the box as easily rebuildable as it looks? Is there available rebuild kits or seals I need?
Any help appreciated,
Jim
bodoger
United States
Grease is supposed to come out there but only give it a shot or two till it comes out otherwise you will just be wasting grease. That greases the Pittman shaft only a small amount is needed.
bodoger
United States
There is another seal in side on the other end of the Pittman shaft that keeps the power steering fluid inside. The outer seal only keeps dirt and water out of the shaft and bearing the grease is the lubrication for the shaft.
bodoger
United States
The outer seal could be changed on the truck but any thing more it would have to be removed. Parts should be available, maybe the other members could chime in about the parts.
