- 170
- 22
- 18
- Abilene, Texas
I've got a bad control box on my M929/A1. I knew it was the control box, but I went ahead and did some electrical tests on the ignition switch to the neutral start switch etc... There is no 566 lead to the alternator for lock-out on this truck. So, I had a spare control box WSU 4001UT which came off a M809 series truck that I installed in place of the WSU 4004UT on the M939 series truck. Everything seems to be normal as far as dash electrical with battery switch on, but it's not letting me start the engine. Something is different with this unit that is locking out the start sequence though. No cranking power through the circuit? All electrical power to dash and protective controls seem to be energized. Parking break signal, and low air pressure warning lights are active etc. Everything looks normal. Starter switch is good too.
Any ideas on what is circuit or switch is keeping the start sequence locked out?
I opened up the WSU 4004UT control unit. The circuit board looks fine. I'm at the point of testing the solenoid and relay inside this unit. If those are good then something on the PCB is bad. Probably a diode or something? The failure symptom with the original control box is... battery switch on... short beep with warning lights and siren, then nothing. You can hear the relay click too. That's it!
