M939 tm
Floridianson
2,521
Interlachen Fl.
Could someone please help me find what TM this air brake part is in to see if we can service it. I tryed to add some air tool oil/cleaner but it has a slow weep on the blow off. If I have to get another one guess I will. This one is on the last tandem. Thanks
juanprado
3,119
Metairie/La (N'awlins)
For the abs equipped trucks you have to use the 5 part -23 series for brake info. It is posted in the tm section.
The brakes are in Tm 9-2320-272-23-3, look at work package 457. That looks like the rear ABS relay valve. There is a whole section on checking and clearing abs trouble codes also.
