Bolkbich
- 7
- 18
- MAHWAH, NJ
3 out of 5 m939 trucks i bought have the air lines to the t-case routed to the wrong place. 2 out of the 3 were that way right from the military. 2 of them had the air lines fom the low range shifter linkage valve( the valve that engages awd when you engage low range) going to the t-case shifter lock... not the axle engagement air piston. 2 of them had the air lines going to the low range shifter linkage valve crossed up so the truck had full line air pressure going to the front axle engagement air piston all the time so the truck was locked in all wheel drive (the parts truck i bought with a blown t-case was locked in all wheel drive..im sure thats why its blown) the other truck had bad cupping on the front tires(pretty good sign its locked in awd) luckily the t-case is ok.... Just a heads up to see if your front axle is locked in. If you cant shift your t-case this could be your issue.(Ive also seen the shaft up in the t-case linkage seized up).
