M939 Transfer case
1,172
Try shifting it with no air pressure.
BKubu
1,119
Gaithersburg, MD
The handle might also be out of adjustment. John Winslow once had an M936A1 that wouldn't engage at all (HIGH or LOW)...it was only an adjustment issue.
Trailboss
137
Norwood LA
I had one that the linkage was frozen by rust. You had to go underneath, disconnect the linkage and manually shift from low to neutral to high with a prybar or soft hammer. Since I almost never needed low range, it really wasn't an issue. I actually started to bend the shift handle before I found that the linkage was frozen.
