M939A2 Air Dryer Question
dodgemain
Sterling Heights, MI
Hi,
I think I am having a problem with the air dryer on my M929A2. Air is always coming out of the port pictured below. Well maybe not always but a lot of the time. Is this normal? What kind of maintenance should be performed on this unit?
GIJoeCzar
26
Sherwood, WI
Air Dryer Issue
dodgemain,
In addition to the other posts I'd recommend that you don't run your truck until the problem is resolved. If in fact your pressure releif valve is bad, which sounds to be the case, you'll burn up an air compressor causing a $35/30 min repair to be a $500/5 hour repair (not to mention the possible tow).
Good luck.
Joe
