M939A2 series CTIS "delete" thru valve in valve stem help
emmado22
147
Mid Hudson Valley NY
All,
I have done a search, I am looking for pics of "what to do" for the how to put the valve in the valve stem to separate the tire from the M939A2 CITS system so the tires don't go flat. Im not interested in the kits I can buy. I need the "low cost way" to do it to help someone out.
Thanks!
MtnSnow
14
NSL, UT
Unscrew the "CTIS hose" from the "CTIS wheel valve" that goes onto the wheel's turret valve stem and when you remove that hose air will start coming out of the tire if it is not flat.
Then take a valve stem tool and remove the "valve stem core" from the CTIS wheel valve and then screw it into the turret valve stem where you removed the CTIS hose from...
If you don't want to remove the valve core from the CTIS wheel valve you can pick up valve stem cores from any automotive parts store when you get a valve stem tool.
Csm Davis
382
Hattiesburg, Mississippi
Because you are doing the whole truck I have both types of valves in the picture the hose I have my hand on is what unscrews from the valve stem and you put the new core into the valve stem here.
