- 16
- 4
- 3
- New Boston, TX
Working on a M977a2. Engine is running and sounds great. With transmission in neutral the engine throttles up and down fine. Once you place the transmission in gear you can no longer throttle. Once we put the transfer case in neutral then you can shift the transmission through all gears and the throttle works just fine but you cannot move with transfer in neutral. Place the transfer in low or high you no longer can throttle. The engine also reacts as if it has an over bearing load on it and lugs with black smoke exiting the exhaust. There are lots of sensors and electrical on this truck. Just curious of where to start? Any assistance would be greatly appreciated.
