M998 2-man filler panels
Ajax MD
1,412
Mayo, MD
Searched through the manuals, and searched the archives here, with little luck.
In the 2-man config, there are 2 types of "filler panels" that I've seen in place of rear doors. There's a solid panel, and a panel where the lower 1/3 of the panel is hinged and held shut with 2 rubber holddowns on the exterior of the body. This little flap allows access to the foot wells of the rear passenger area which serves as stowage in the 2-man config.
The Army (or someone) slapped on a set of the hinged filler panels on the truck where it never had them before. There are no holes in the main body for the rubber hold-down catches. The rubber holddowns themselves are missing.
Can anyone point me to the NSN or P/N for the correct size rubber holddown? I'll drill the necessary holes for the catches in the body.
See pic for reference:
DREDnot
434
Phoenix, AZ
Those hold downs are the same ones used on the doghouse.
They are more expensive than they look like they should be.
They are also a pain in the leg when you catch yourself on one.
I got myself one of the later style fillers and went with a cheaper and all around better method of securing the flap door.
