M998 6.2L 3speed Important Spare Parts for Road Trip
Lit_Armo
9
California
Hi everyone I have an M998 1987 4 man Humvee, with a 6.2L 3 Speed, and was wondering what spare parts could I buy right now incase something happens on the road. I have a scissor jack and will get a spare tire soon. I've checked and I have V belts on, but how many and which models should I get? And what else could I need? Thank you!
98G
Former SSG
4,191
Most of what you might need can be found at O'Reilly and similar places. It's more likely that you'll need something you don't have with you, no matter how well prepared you are.
My 1986 M998 has been driven thousands of miles all over the country and never needed anything.
A spare, a jack, a basic tool set, and some $ just in case are all I carry in the hmmwv.
Lit_Armo
9
California
Thank you, I appreciate the advice!
TOBASH
3,246
Brooklyn, NY
All axles. 2 spare tires. Lots of water. Sat phone or sat text device. 24 volt inverter with plug in air pump. ATF. Camera to send us pics. Matches in watertight container. Dried food. Blankets. Knife. Fix a flat plugs and rubber plugs.
Lit_Armo
9
California
Thank you for the advice! For the 24volt inverter with plug in air pump, do you have any models Im seeing the 24volt power inverters in different watts and amps, and not seeing ones with a plug in air pump?
Here’s a pic of my ride :)
1987 M998 Cargo/Troop Carrier
Coug
4,239
Olympia/WA
with the replacement axles also add new bolts for the axles. More than one vehicle has gotten stuck when the halfshaft bolts backed out and sheared off.
Checking all the bolts with a torque wrench before you go will also be very beneficial.
Lit_Armo
9
California
To confirm, these are the bolts?
5745686
KIT, HALFSHAFT MOUNTING BOLTS & WASHERS (EACH) [PRE-APPLIED LOCTITE]
Found it on HPG site.
Coug
4,239
Olympia/WA
5745686
Yes, those are them. You are technically overtorqueing them compared to their rating, so a lot of people recommend you replace them every time you do anything.
Some people recommend NordLock washers instead of split ring, but that's a personal choice.
FlameRed
450
Florida
:ditto:
A cell phone and AAA membership for a tow. Just let them know you need a standard flatbed - it will fit. But if you are stuck off road, best to go with some buddies that can drag you out as AAA won't do off road recoveries.
Lit_Armo
9
California
:ditto:
Appreciate it I just remembered I have Hagerty nationwide and they have an included road club 20mile tow service
TOBASH
3,246
Brooklyn, NY
Two separate items.
-Plug in air pump 110 Volt
-24 Volt to 110V inverter
